Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mercedes-Benz infrared car key repair
Ce dont vous avez besoin
    1. Mercedes-Benz infrared car key repair, Preparation: étape 1, image 1 de 3 Mercedes-Benz infrared car key repair, Preparation: étape 1, image 2 de 3 Mercedes-Benz infrared car key repair, Preparation: étape 1, image 3 de 3
      • Make sure you have all necessary tools at hand and pre-heat your soldering station.
      • Remove the rear cover of the key and take out the battery. The best way to disassemble the key is to carefully press or lever the front apart with a screwdriver.
      • Once you've extracted the board, clamp it in the vice and identify the four solder joints that hold the button on the board.
      Demander à FixBot
      Ajouter un commentaire
    2. Mercedes-Benz infrared car key repair, Re-solder the button to the board: étape 2, image 1 de 3 Mercedes-Benz infrared car key repair, Re-solder the button to the board: étape 2, image 2 de 3 Mercedes-Benz infrared car key repair, Re-solder the button to the board: étape 2, image 3 de 3
      • Either you've already noticed by now that the button has completely detached from the board, or you will now see that the solder joints are cold, meaning they're only merely holding the button.
      • Your job will now consist of re-soldering all 4 joints correctly, so that the button is firmly attached to the board again.
      Demander à FixBot
    3. Mercedes-Benz infrared car key repair, Cleaning off the old solder: étape 3, image 1 de 3 Mercedes-Benz infrared car key repair, Cleaning off the old solder: étape 3, image 2 de 3 Mercedes-Benz infrared car key repair, Cleaning off the old solder: étape 3, image 3 de 3
      • Before you do that, however, you'll need to remove all remains of the old solder joints.
      • Apply heat to the joint. Once the solder liquifies, clean the spot with the desoldering braid.
      • The soldering iron radiates extreme heat! Be careful not to damage the capacitors, or you've had it.
      • Make sure to do that on all four joints.
      Demander à FixBot
    4. Mercedes-Benz infrared car key repair, Apply new solder: étape 4, image 1 de 2 Mercedes-Benz infrared car key repair, Apply new solder: étape 4, image 2 de 2
      • Now, you can start to re-apply new solder to the four spots that should hold your button in place.
      Demander à FixBot
    5. Mercedes-Benz infrared car key repair, Check function: étape 5, image 1 de 3 Mercedes-Benz infrared car key repair, Check function: étape 5, image 2 de 3 Mercedes-Benz infrared car key repair, Check function: étape 5, image 3 de 3
      • Once you've re-soldered all four joints, take the board out of the vice and check the function with a multimeter.
      • While you won't be able to see the infrared light with your bare eyes, a smartphone camera should do the trick.
      Demander à FixBot
    6. Mercedes-Benz infrared car key repair, Reassemble the key: étape 6, image 1 de 1
      • This is how your board looks like when you're finished.
      • Now, carefully reassemble the key.
      • In some cases, you may have to glue the housing together.
      Demander à FixBot
Good luck with your repair!
Sandra Hiller
Membre depuis le 10/17/16
35 389 Réputation
8 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
51 334 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 33
30 derniers jours : 140
Total : 3,752
