Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Merch Source Projector Entertainment II Cooling Fan Replacement
Ce dont vous avez besoin
    1. Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: étape 1, image 1 de 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: étape 1, image 2 de 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Demander à FixBot
      Ajouter un commentaire
    2. Merch Source Projector Entertainment II Cooling Fan Replacement: étape 2, image 1 de 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Demander à FixBot
    3. Merch Source Projector Entertainment II Cooling Fan Replacement: étape 3, image 1 de 2 Merch Source Projector Entertainment II Cooling Fan Replacement: étape 3, image 2 de 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Demander à FixBot
    1. Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: étape 4, image 1 de 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: étape 4, image 2 de 2
      • Locate the 80 mm fan and slide upward straight out of the housing.
      Demander à FixBot
    2. Merch Source Projector Entertainment II Cooling Fan Replacement: étape 5, image 1 de 2 Merch Source Projector Entertainment II Cooling Fan Replacement: étape 5, image 2 de 2
      • Unsolder the red and black connections off of the motherboard.
      • If there are zip ties around the cables, they will need to be cut to remove the fan.
      • Need some help? Follow this guide to learn soldering basics.
      • While soldering the metal connections will get very hot. Never touch the iron with your hand.
      • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
      • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
      Demander à FixBot
Stephanie
Membre depuis le 01/08/15
282 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 18-3, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 membres
48 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 34
30 derniers jours : 50
Total : 2,877
