Introduction
Dim picture? No display? Discolored output? No problem! Use this guide to replace the burnt light bulb with a new one. To complete this replacement, you will need the following parts ready:
Ce dont vous avez besoin
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Remove the light bulb from its housing unit.
Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
Un commentaire
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
