Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Merch Source Projector Entertainment II Motherboard
Ce dont vous avez besoin
    1. Merch Source Projector Entertainment II Motherboard, Outer Casing: étape 1, image 1 de 2 Merch Source Projector Entertainment II Motherboard, Outer Casing: étape 1, image 2 de 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Demander à FixBot
      Ajouter un commentaire
    2. Merch Source Projector Entertainment II Motherboard: étape 2, image 1 de 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Demander à FixBot
    3. Merch Source Projector Entertainment II Motherboard: étape 3, image 1 de 2 Merch Source Projector Entertainment II Motherboard: étape 3, image 2 de 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Demander à FixBot
    1. Merch Source Projector Entertainment II Motherboard, Motherboard: étape 4, image 1 de 2 Merch Source Projector Entertainment II Motherboard, Motherboard: étape 4, image 2 de 2
      • Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
      • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
      • Once the housing is disengaged, the ribbon cable should slide out easy. Do not pull too hard on the ribbon cable as it is very fragile.
      Demander à FixBot
    2. Merch Source Projector Entertainment II Motherboard: étape 5, image 1 de 2 Merch Source Projector Entertainment II Motherboard: étape 5, image 2 de 2
      • Unscrew the three 6 mm screws from the motherboard with the Phillips #0 screwdriver.
      • Be sure not to damage any of the wires atached to the motherboard.
      Demander à FixBot
    3. Merch Source Projector Entertainment II Motherboard: étape 6, image 1 de 2 Merch Source Projector Entertainment II Motherboard: étape 6, image 2 de 2
      • Solder off all of the connections on the motherboard with a soldering iron.
      • Once connections are soldered off, the motherboard should be detached and ready for replacement.
      • Need some help? Follow this guide to learn soldering basics.
      • While soldering the metal connections can get very hot. Never touch the iron with your hand. also make sure that the projector is fully turned off and not plugged in.
      • If there is hot glue on top on the connection with the motherboard, you will need to peel it off using your fingers.
      Demander à FixBot
Michael Tan
Membre depuis le 01/08/15
590 Réputation
3 tutoriels rédigés
3 commentaires de tutoriel
Was wondering if you could help me identify a microchip on the board by the speaker?
Brad Langland - Réponse Partager
Where can I get parts for the projector? I think my board is cooked.
Delgtm - Réponse Partager
mine acts like it does not recognize the rca cords. help
Kamela Mitchell - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 31
30 derniers jours : 50
Total : 2,458
