Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Merch Source Projector Entertainment II Outer Lens Replacement
Ce dont vous avez besoin
    1. Merch Source Projector Entertainment II Outer Lens Replacement, Outer Casing: étape 1, image 1 de 2 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Casing: étape 1, image 2 de 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Demander à FixBot
      Ajouter un commentaire
    2. Merch Source Projector Entertainment II Outer Lens Replacement: étape 2, image 1 de 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Demander à FixBot
    3. Merch Source Projector Entertainment II Outer Lens Replacement: étape 3, image 1 de 2 Merch Source Projector Entertainment II Outer Lens Replacement: étape 3, image 2 de 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Demander à FixBot
    1. Merch Source Projector Entertainment II Outer Lens Replacement, Ribbon Cable Detachment: étape 4, image 1 de 2 Merch Source Projector Entertainment II Outer Lens Replacement, Ribbon Cable Detachment: étape 4, image 2 de 2
      • Use the plastic opening tool to gently disengage the black clip housing from the ribbon cable.
      • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
      • Once the housing is disengaged, the ribbon cable should slide out easily. Do not pull too hard on the ribbon cable as it is very fragile.
      Demander à FixBot
    2. Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: étape 5, image 1 de 3 Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: étape 5, image 2 de 3 Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: étape 5, image 3 de 3
      • Unscrew the three 7 mm screws from the motherboard with the Phillips #0 screw driver.
      • Once loose, lift the motherboard off of the lens casing, and move it away from the workspace.
      • Be sure not to damage any of the wires atached to the motherboard.
      Demander à FixBot
    3. Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: étape 6, image 1 de 3 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: étape 6, image 2 de 3 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: étape 6, image 3 de 3
      • Unscrew the four 15mm Phillips screws using the Phillips #0 screw driver.
      • Unscrew the two 12mm Phillips screws using the Phillips #0 screw driver.
      • Gently remove the entire lens casing from its position.
      Demander à FixBot
    4. Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: étape 7, image 1 de 3 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: étape 7, image 2 de 3 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: étape 7, image 3 de 3
      • Using the plastic opening tool, slightly separate the casing holding the large lens in place.
      • Separate the casing completely from the inner lens using your hands.
      • This should release the outer lens and it's immediate casing.
      • As you separate the outer casing, the lens and digital display box may fall out of their encasement.
      • Although there are threads connecting the outer lens casing and the inner lens casing, do not be fooled. The outer lens casing cannot be disconnected by unscrewing it.
      Demander à FixBot
    5. Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: étape 8, image 1 de 3 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: étape 8, image 2 de 3 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: étape 8, image 3 de 3
      • Unscrew the four 8mm Phillips screws at the base of the outer lens casing using the Phillips #0 screw driver.
      • Separate the white outer casing from the black outer casing.
      Demander à FixBot
    6. Merch Source Projector Entertainment II Outer Lens Replacement, Final Outer Lens Removal: étape 9, image 1 de 2 Merch Source Projector Entertainment II Outer Lens Replacement, Final Outer Lens Removal: étape 9, image 2 de 2
      • Using your finger, gently push the lens out of its white encasement.
      • The outer lens is now free and ready for replacement.
      Demander à FixBot
2 autres ont terminé cette réparation.
Stephanie
Membre depuis le 01/08/15
282 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 18-3, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 membres
48 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 60
Total : 3,688
