Introduction
Use this guide to replace the piston rings on a Mi-T-M Air Compressor AM1-PH65-08HD 2012.
Ce dont vous avez besoin
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Pull the ring on the safety relief valve away from the compressor tank to drain the air from the compressor.
Use a 7/8 inch wrench to loosen the nut securing the pump discharge line to the elbow on the cylinder head.
Use a 10 mm socket to remove the bolt securing the belt guard.
Tilt the belt guard away from the device and lift it out to remove it.
Use a 7/16 inch socket to remove the nuts and accompanying bolts securing the belt guard bracket to the rear belt guard.
Lift the belt guard bracket straight up to remove it.
Use a 1/2 inch socket to remove the six bolts and washers securing the cylinder to the crankcase.
Rotate the top compression ring until its gap is facing you.
Push the left side of the compression ring completely into the compression ring groove.
Rotate the top oil ring rail so that its gap is facing you.
Use a pair of needle nose pliers to lift up the left end of the top oil ring rail enough to grip it with your fingers.
Rotate the oil ring expander so that its gap is facing you.
Use a pair of needle nose pliers to lift up the left end of the top oil ring expander enough to grip it with your fingers.
Use your fingers to lift the oil ring expander out of its groove, working your way clockwise around the piston.
Remove the oil ring expander and set it aside.
Rotate the bottom oil ring rail so that its gap is facing you.
Use a pair of needle nose pliers to lift up the left end of the bottom oil ring rail enough to grip it with your fingers.
Use your fingers to lift up the bottom oil ring rail, working your way clockwise around the piston.
Remove the bottom oil ring rail and set it aside.
Repeat the last seven steps to remove the piston rings from the second piston.
Insert the left end of the replacement oil ring expander into the oil ring groove.
Continue inserting the oil ring expander into the groove by working your way around the piston clockwise.
Insert the left end of the replacement top oil ring rail into the oil ring groove directly above the oil ring expander.
Continue inserting the top oil ring rail into the groove by working your way around the piston clockwise.
Repeat this step for the bottom oil ring rail.
Rotate one piston to top dead center.
Align the upper piston with its corresponding cylinder.
While holding the cylinder closely aligned with the piston, use one hand to compress the piston rings.
With the piston rings compressed, begin to lower the cylinder onto the upper piston.
To reassemble your device, follow these instructions in reverse order starting at step 12.
