Aller au contenu principal
Miadore Classic N64 Controller Joystick Replacement
Ce dont vous avez besoin
  1. Miadore Classic N64 Controller Joystick Replacement, Joystick: étape 1, image 1 de 3 Miadore Classic N64 Controller Joystick Replacement, Joystick: étape 1, image 2 de 3 Miadore Classic N64 Controller Joystick Replacement, Joystick: étape 1, image 3 de 3
    • Unscrew all nine 3.2 mm Phillips #000 screws from the back of the controller.
    • Remove the back panel of the controller.
  2. Miadore Classic N64 Controller Joystick Replacement: étape 2, image 1 de 2 Miadore Classic N64 Controller Joystick Replacement: étape 2, image 2 de 2
    • Remove the three 3.2 mm Phillips #000 screws holding the motherboard in place.
    • The motherboard will still be in place after the screws are removed.
  3. Miadore Classic N64 Controller Joystick Replacement: étape 3, image 1 de 3 Miadore Classic N64 Controller Joystick Replacement: étape 3, image 2 de 3 Miadore Classic N64 Controller Joystick Replacement: étape 3, image 3 de 3
    • Remove the three 3.2 mm Phillips #000 screws holding the joystick module in place.
    • Remove the joystick module.
  4. Miadore Classic N64 Controller Joystick Replacement: étape 4, image 1 de 2 Miadore Classic N64 Controller Joystick Replacement: étape 4, image 2 de 2
    • Remove the joystick by pulling it away from the needle-like object holding it in place.
    • Replace it with a new or custom joystick.
To reassemble your device, follow these instructions in reverse order. If all goes well, the joystick should work good as new.
Anderson Rodriguez
Membre depuis le 09/16/24
192 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-3, Kershman Fall 2024 Membre de l'équipe CSU Los Angeles, Team 5-3, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G3
5 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 19
30 derniers jours : 75
Total : 213
