Introduction
Almost every watchmaker from Casio to Rolex produces watches with link bands. When adjusting or repairing a band becomes necessary, adding and removing links with a few special tools is the only solution. This comprehensive guide will demonstrate how to properly perform such manipulations on a Michael Kors brand wristwatch.
Pièces
Aucune pièce spécifiée.
Place the watch on your wrist and determine whether links should be added or removed.
If watchband needs to be expanded, approximate the number of links required.
When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
look on the inside of the band, a lot of manufacturers put a directional arrow to show you which way to remove/insert the band pin, this is because these pins have a larger end on one side, if no arrow is present then removal is bi-directional…having said this, make sure your band doesn’t use screw pins, high grades like Rolex and others use screws….
6 autres ont terminé cette réparation.
8 commentaires
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
How can I puchace the first link on my Michael kors ceramic watch
I need first link to attach to micheal kors ceramic white watch
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Where can I get the white bands that cover the links on my my watch as a few have bits broken
Where can I get the white rubber link covers for strap on my mk watch
I need extra links for the MK-5249, where can I get them?
How do you get extra links for my husband watch
I need 1 or 2 linked added to my Michael kors watch
Jeremy Bendy - Réponse
I need 2 silver band
pansy parsons - Réponse
