Aller au contenu principal
Microsoft Band 2 defective battery connection/ribbon Replacement
Ce dont vous avez besoin
  1. Microsoft Band 2 defective battery connection/ribbon Replacement, defective battery connection/ribbon: étape 1, image 1 de 3 Microsoft Band 2 defective battery connection/ribbon Replacement, defective battery connection/ribbon: étape 1, image 2 de 3 Microsoft Band 2 defective battery connection/ribbon Replacement, defective battery connection/ribbon: étape 1, image 3 de 3
    • Carve away *almost* all of the rubber of the straps. (Leave the rubber surrounding the battery/heart rate clasp end.)
  2. Microsoft Band 2 defective battery connection/ribbon Replacement: étape 2, image 1 de 3 Microsoft Band 2 defective battery connection/ribbon Replacement: étape 2, image 2 de 3 Microsoft Band 2 defective battery connection/ribbon Replacement: étape 2, image 3 de 3
    • Partly dissassemble the battery clasp end: pry up the silver clasp face that is taped down, unscrew the four T3 Torx , remove that cover, remove the battery
  3. Microsoft Band 2 defective battery connection/ribbon Replacement: étape 3, image 1 de 2 Microsoft Band 2 defective battery connection/ribbon Replacement: étape 3, image 2 de 2
    • Remove the plastic 'sandwiching' the ribbon as it travels into the clasp end, with a Dremel or knife. (Picture 2 illustrates the removed plastic.)
  4. Microsoft Band 2 defective battery connection/ribbon Replacement: étape 4, image 1 de 2 Microsoft Band 2 defective battery connection/ribbon Replacement: étape 4, image 2 de 2
    • Sand the ribbon to expose the conductors on both sides. Be careful to keep the insulator in between the two conductors intact, so they don't short. The second picture shows a 10x image of the layers of copper and insulator.
  5. Microsoft Band 2 defective battery connection/ribbon Replacement: étape 5, image 1 de 3 Microsoft Band 2 defective battery connection/ribbon Replacement: étape 5, image 2 de 3 Microsoft Band 2 defective battery connection/ribbon Replacement: étape 5, image 3 de 3
    • Wrap the repaired break with insulating tape. Sand away outer insulator on both sides to make soldering locations for jumper strips.
  6. Microsoft Band 2 defective battery connection/ribbon Replacement: étape 6, image 1 de 1
    • Use Sugru to wrap/stabilize the repair and integrate it into the clasp end's rubber.
  7. Microsoft Band 2 defective battery connection/ribbon Replacement: étape 7, image 1 de 1
    • Drill two holes into clasp-end plastic tabs, and two holes on each side of watch face's 'shoulders', as anchor points for thread to fasten strap leather. (Hole locations are the black dots on the gold metal near the silver casing.)
  8. Microsoft Band 2 defective battery connection/ribbon Replacement: étape 8, image 1 de 3 Microsoft Band 2 defective battery connection/ribbon Replacement: étape 8, image 2 de 3 Microsoft Band 2 defective battery connection/ribbon Replacement: étape 8, image 3 de 3
    • Build new leather straps; fasten using thread through holes & glue.
Your Rand 2 should (!) hold a charge now. Not sure how durable this repair is.
2 autres ont terminé cette réparation.
Kirk McDermid
Membre depuis le 08/20/17
171 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 20
Total : 3,292
