Aller au contenu principal
Microsoft Band Motherboard Replacement
Ce dont vous avez besoin
  1. Microsoft Band Motherboard Replacement, Screen Frame: étape 1, image 1 de 1
    • To avoid burning your hands, make sure to hold only the thin edges of the iOpener.
    • Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
    • Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
    • When using the iOpener, make sure to wrap it partially around the sides.
  2. Microsoft Band Motherboard Replacement: étape 2, image 1 de 1
    • Using a spudger, lightly press upwards against one corner of the frame, then the other along the corner of the short edge.
    • Alternating between the same two corners, continue pressing until there's about a 1-2 mm gap between that end of the frame and the body.
  3. Microsoft Band Motherboard Replacement: étape 3, image 1 de 2 Microsoft Band Motherboard Replacement: étape 3, image 2 de 2
    • Do not pull the frame away too quickly. The screen may be stuck to the frame, and pulling on it could cause damage. If the screen is still attached, lightly push on the screen with a finger and it should pop out.
    • Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
    • If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
    • When re-assembling, make sure the frame's microphone hole is on the same side as the sensor board underneath.
  4. Microsoft Band Motherboard Replacement, LCD Screen: étape 4, image 1 de 1
    • Do not rip the yellow ribbon cable from the motherboard.
    • Gently lift the LCD screen from the components using your fingertips.
  5. Microsoft Band Motherboard Replacement: étape 5, image 1 de 1
    • Lightly pry up the black connector from the motherboard using a spudger.
    • Pull the entire LCD screen gently upward to detach the yellow ribbon cable.
  6. Microsoft Band Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Using the spudger or the plastic opening tool, gently lift the sensor ribbon.
  7. Microsoft Band Motherboard Replacement: étape 7, image 1 de 2 Microsoft Band Motherboard Replacement: étape 7, image 2 de 2
    • Using the spudger or the tweezers, gently detach the golden connector from the motherboard.
  8. Microsoft Band Motherboard Replacement: étape 8, image 1 de 1
    • Using the T3 Torx screwdriver, remove the two 2 mm T3 screws.
    • When you are reassembling, lift the sensor ribbon so that it's not in the way.
  9. Microsoft Band Motherboard Replacement: étape 9, image 1 de 1
    • Be gentle. Make sure not to rip apart the cord underneath that connects the heart-rate monitor to the motherboard.
    • Using the spudger and your fingers, gently lift the motherboard from the band socket.
    • You should feel a "pop."
  10. Microsoft Band Motherboard Replacement: étape 10, image 1 de 3 Microsoft Band Motherboard Replacement: étape 10, image 2 de 3 Microsoft Band Motherboard Replacement: étape 10, image 3 de 3
    • Gently flip the motherboard so that you are viewing the motherboard from underneath.
    • Using the tweezers, gently detach the golden connector from the back of the motherboard.
7 autres ont terminé cette réparation.
Takuma Yonebayashi
Membre depuis le 01/28/15
326 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-34, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 membres
6 tutoriels rédigés
Un commentaire
Thanks! that was useful
ASDF ASDF - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,929
