Aller au contenu principal
Microsoft Lumia 640 XL Touch Screen Replacement
Ce dont vous avez besoin
  1. Microsoft Lumia 640 XL Touch Screen Replacement, Battery: étape 1, image 1 de 3 Microsoft Lumia 640 XL Touch Screen Replacement, Battery: étape 1, image 2 de 3 Microsoft Lumia 640 XL Touch Screen Replacement, Battery: étape 1, image 3 de 3
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Touch Screen Replacement: étape 2, image 1 de 2 Microsoft Lumia 640 XL Touch Screen Replacement: étape 2, image 2 de 2
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: étape 3, image 1 de 3 Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: étape 3, image 2 de 3 Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: étape 3, image 3 de 3
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Touch Screen Replacement: étape 4, image 1 de 3 Microsoft Lumia 640 XL Touch Screen Replacement: étape 4, image 2 de 3 Microsoft Lumia 640 XL Touch Screen Replacement: étape 4, image 3 de 3
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
  5. Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: étape 5, image 1 de 2 Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: étape 5, image 2 de 2
    • Remove all three T3, 2.66 mm screws.
  6. Microsoft Lumia 640 XL Touch Screen Replacement: étape 6, image 1 de 3 Microsoft Lumia 640 XL Touch Screen Replacement: étape 6, image 2 de 3 Microsoft Lumia 640 XL Touch Screen Replacement: étape 6, image 3 de 3
    • Lift off connector with tweezers.
    • Lift motherboard off with tweezers and pull away with fingers.
  7. Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: étape 7, image 1 de 2 Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: étape 7, image 2 de 2
    • Remove the screen from the device.
    • Touch screen digitizer and screen glass are one unit.
Madelyn Kolterman
Membre depuis le 10/17/18
507 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 4
Total : 1,170
