Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface 2 I/O Cable Replacement
Vues: 5,5 k
Afficher les statistiques :
Dernières 24 heures :
3
Sept derniers jours :
22
Trente derniers jours :
104
Total :
5 489
Commentaires: 7
5 commentaires d'étapes, 2 commentaires de tutoriel.
Aller aux commentaires de tutoriel
Terminé: 4
4 personnes ont marqué ce tutoriel comme « terminé ». Serez-vous la prochaine ?
Favoris: 1
1 personne a mis ce tutoriel en favori (et s'y est abonnée). Serez-vous la prochaine ?
Temps nécessaire: 10 - 20 minutes
Difficulté: Facile
If you have tried multiple times but cannot get the Microsoft Surface 2 to turn on, you may need to replace the I/O cable, which houses the charging port. This cable will also need to be replaced if your SD card slot is not working properly.
Ce dont vous avez besoin
Outils
    1. Microsoft Surface 2  I/O Cable Replacement, Screen: étape 1, image 1 de 3 Microsoft Surface 2  I/O Cable Replacement, Screen: étape 1, image 2 de 3 Microsoft Surface 2  I/O Cable Replacement, Screen: étape 1, image 3 de 3
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      Demander à FixBot
      Ajouter un commentaire
    2. Microsoft Surface 2  I/O Cable Replacement: étape 2, image 1 de 3 Microsoft Surface 2  I/O Cable Replacement: étape 2, image 2 de 3 Microsoft Surface 2  I/O Cable Replacement: étape 2, image 3 de 3
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      Demander à FixBot
    1. Microsoft Surface 2  I/O Cable Replacement, I/O Cable: étape 3, image 1 de 2 Microsoft Surface 2  I/O Cable Replacement, I/O Cable: étape 3, image 2 de 2
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      Demander à FixBot
    2. Microsoft Surface 2  I/O Cable Replacement: étape 4, image 1 de 2 Microsoft Surface 2  I/O Cable Replacement: étape 4, image 2 de 2
      • Remove the two 2.19 mm T3 screws that hold down the SD card ribbon cable.
      • Remove the two 3.27 mm T3 screws holding down the charging port.
      Demander à FixBot
    3. Microsoft Surface 2  I/O Cable Replacement: étape 5, image 1 de 3 Microsoft Surface 2  I/O Cable Replacement: étape 5, image 2 de 3 Microsoft Surface 2  I/O Cable Replacement: étape 5, image 3 de 3
      • Use a spudger to pry up the retaining plate at the end of the ribbon cable.
      • The retaining chip may be glued to the motherboard.
      • Use the spudger to flip up the small retaining flap on the cable's zero insertion force connector.
      • Make sure you are prying up on the retaining flap, not the connector itself.
      • Remove the ribbon cable from its port.
      • No force is needed to plug in or remove the ribbon cable.
      Demander à FixBot
4 autres ont terminé cette réparation.
Gregory Miller
Membre depuis le 02/04/16
415 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 3-1, Wollert Spring 2016 Membre de l'équipe USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 membres
60 tutoriels rédigés
I want to replace the battery of Microsoft Surface 2, which steps I have to follow to replace it?
Piero Sabino - Réponse Partager
Cosa devo utilizzare per attaccare il cavo del display sotto al fermaglio di distanza, colla o nastro biadesivo?
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 22
30 derniers jours : 104
Total : 5,489
