Introduction
Follow this guide to remove or replace a malfunctioning SD card reader in a Microsoft Surface Book.
The Realtek RTS5314 SD card reader, located near the two USB ports, is easy to remove and replace. Make sure that you have a place to hold onto the tiny screws as you remove them.
Ce dont vous avez besoin
Press and hold the Detach button on the keyboard.
Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
Remove the display.
Flip open the display as far as it will go.
Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
Firmly push the paper clip into the hole.
Pull the base away from the display to detach it.
With one side detached, pull firmly to pivot the display out to disconnect the second side.
Orient your keyboard with the internals facing up and the USB ports on the right.
2 commentaires
Awesome guide! Do you know where to find a replacement module?
