Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Headphones Motherboard Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Headphones Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Microsoft Surface Headphones Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Firmly grasp the ear cushions and rotate them counterclockwise, about 45 degrees, until you hear a "click."
    • To replace the motherboard, you only need to remove the right cushion, labeled with an "R" on the headband.
  2. Microsoft Surface Headphones Motherboard Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 2.6 mm screws securing the right speaker housing to the chassis.
  3. Microsoft Surface Headphones Motherboard Replacement: étape 3, image 1 de 1
    • Lift the speaker housing away from the chassis, taking care not to damage the motherboard connections.
    • Desolder the two speaker motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
  4. Microsoft Surface Headphones Motherboard Replacement: étape 4, image 1 de 1
    • Desolder the red and black speaker connections.
  5. Microsoft Surface Headphones Motherboard Replacement: étape 5, image 1 de 1
    • Desolder the 23 connections from the motherboard.
    • Before soldering the connections to your new motherboard, be sure to pay close attention to which wire goes where; they're very easy to mix up.
  6. Microsoft Surface Headphones Motherboard Replacement: étape 6, image 1 de 1
    • Use a Torx screwdriver to remove the four screws.
    • Lift the motherboard up and out of the chassis.
6 autres ont terminé cette réparation.
Ethan Haight
Membre depuis le 02/08/22
933 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 23
Total : 1,585
