Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement
Ce dont vous avez besoin
    1. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 2
      • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Demander à FixBot
      Ajouter un commentaire
    1. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Flip the laptop over: étape 2, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Flip the laptop over: étape 2, image 2 de 2
      • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
      Demander à FixBot
    2. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Feet removal information: étape 3, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Feet removal information: étape 3, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Feet removal information: étape 3, image 3 de 3
      • Each foot has a recess to help pry it from the laptop:
      • The back feet recesses are closest to the back edge of the laptop.
      • The front feet recesses are closest to the front edge of the laptop.
      Demander à FixBot
    3. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the feet: étape 4, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the feet: étape 4, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the feet: étape 4, image 3 de 3
      Outil utilisé dans cette étape :
      • Insert one arm of your tweezers into the recess of one of the feet.
      • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
      • The feet eject very quickly—be careful not to lose them.
      • Remove the foot.
      • Repeat this process on the remaining feet.
      Demander à FixBot
    4. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Reassembly information: étape 5, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Reassembly information: étape 5, image 2 de 2
      Tesa 61395 Tape
      $8.95
      • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
      • The rear feet have a single center clip.
      • The front feet have three clips and can only be reinserted one way.
      • Press the feet into their recesses to secure them to the frame.
      • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
      Demander à FixBot
    5. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement: étape 6, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement: étape 6, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement: étape 6, image 3 de 3
      • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
      • Peel a pad away from its backing.
      • Align the pad over a foot cavity and press down to secure it.
      Demander à FixBot
    1. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Unfasten the upper case: étape 7, image 1 de 1
      FixMat
      $36.95
      • These screws strip easily. Apply constant, downward force to prevent stripping.
      • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
      Demander à FixBot
    2. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Open the screen: étape 8, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Open the screen: étape 8, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Open the screen: étape 8, image 3 de 3
      • Flip your laptop over and fully open the screen.
      Demander à FixBot
    3. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Lift the upper case: étape 9, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Lift the upper case: étape 9, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Lift the upper case: étape 9, image 3 de 3
      • The upper case is secured by magnets.
      • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
      • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
      • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
      • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
      • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
      Demander à FixBot
    4. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Disconnect the keyboard and touchpad cable: étape 10, image 3 de 3
      • The keyboard and touchpad cable connects the upper case to the laptop.
      • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
      • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
      Demander à FixBot
    5. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the upper case: étape 11, image 1 de 1
      • Remove the upper case and set it keyboard-side down on a clean surface.
      Demander à FixBot
    1. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Reassembly information: étape 12, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Reassembly information: étape 12, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Reassembly information: étape 12, image 3 de 3
      Microfiber Cleaning Cloths
      $3.99
      • Your SSD has thermal paste that forms a bond to the upper case.
      • During reassembly:
      • Use the flat end of your spudger to scrape away old thermal paste from the top of the SSD and the underside of the upper case.
      • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the SSD and upper case. Wipe away the residue using a lint-free or microfiber cloth.
      • Replace the thermal pad with one that's the same size as the SSD sticker.
      • Alternatively, you can apply a bead of thermal paste directly to the SSD's label. Use the dot method with a bead slightly larger than the screw head securing the SSD.
      Demander à FixBot
    1. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Unfasten the SSD: étape 13, image 1 de 1
      • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
      • With the screw removed, the SSD pops up at a shallow angle.
      Demander à FixBot
    2. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the SSD: étape 14, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the SSD: étape 14, image 2 de 2
      • Removing the SSD also functions as a battery disconnect.
      • Pull the SSD out of its socket and remove it.
      • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
      • During reassembly, insert the SSD at a slight angle.
      Demander à FixBot
    1. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the heatsink shield tape: étape 15, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the heatsink shield tape: étape 15, image 2 de 2
      • Conductive tape attaches the left edge of the heatsink shield to the heatsink.
      • Heat the tape with a heat gun or hair dryer to soften its adhesive.
      • Use tweezers or your fingers to remove the tape.
      • During reassembly, apply the tape in the same location it came from. Reheat the adhesive if the tape doesn’t stick well to the heatsink at first.
      Demander à FixBot
    1. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the tape: étape 16, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the tape: étape 16, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the tape: étape 16, image 3 de 3
      • Remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
      • Set the tape aside. You'll use it during reassembly.
      Demander à FixBot
    2. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Unclip the heatsink shield: étape 17, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Unclip the heatsink shield: étape 17, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Unclip the heatsink shield: étape 17, image 3 de 3
      • Try not to deform the shield too much. You'll need to reinstall it during reassembly.
      • Insert the pointed end of a spudger in one of the gaps on the top edge of the heatsink shield.
      • Gently pry up to release the clips securing the shield.
      • Repeat this process along the right edge.
      • Insert one arm of your tweezers under the bottom right edge of the heatsink shield.
      • Gently pry up to release the remaining clips.
      Demander à FixBot
    3. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the heatsink shield: étape 18, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the heatsink shield: étape 18, image 2 de 2
      • Remove the heatsink shield.
      • To reinstall a shield, press down around its perimeter to engage the shield clips.
      Demander à FixBot
    4. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Disconnect the fan: étape 19, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Disconnect the fan: étape 19, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Disconnect the fan: étape 19, image 3 de 3
      • Use the pointed end of a spudger to flip up the locking flap on the fan cable ZIF connector.
      • Grip the fan cable pull-tab with tweezers and pull the cable straight out of the connector.
      Demander à FixBot
    5. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Separate the cable adhesive: étape 20, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Separate the cable adhesive: étape 20, image 2 de 2
      • Adhesive secures the fan cable to the frame.
      • Use tweezers or your fingers to peel the fan cable from the frame and separate its adhesive.
      Demander à FixBot
    6. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Unfasten the heatsink: étape 21, image 1 de 1
      • Use a T3 Torx driver to remove the ten screws securing the heatsink:
      • Two 2.5 mm screws
      • Three 2.0 mm screws
      • One 3.0 mm screw
      • Two 4.1 mm screws
      • Two 3.4 mm screws
      Demander à FixBot
    7. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Reassembly note: étape 22, image 1 de 1
      • Align the heatsink with the centering peg on the motherboard.
      • Tighten the four CPU tension screws in an “X” pattern. For example: top left, bottom right, top right, bottom left.
      Demander à FixBot
    8. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Lift the heatsink: étape 23, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Lift the heatsink: étape 23, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Lift the heatsink: étape 23, image 3 de 3
      • Thermal paste bonds the heatsink to the CPU.
      • Insert your spudger under the left heat pipe.
      • Pry up to release the left section of the heatsink.
      • This may take some force. Be careful not to bend the heat pipes.
      • Repeat this procedure for the right heat pipe and the CPU screw mounts until the heatsink is completely separated from the motherboard.
      Demander à FixBot
    9. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Clear the alignment peg: étape 24, image 1 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Clear the alignment peg: étape 24, image 2 de 3 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Clear the alignment peg: étape 24, image 3 de 3
      • Use your finger to lift the right edge of the heatsink up and over the alignment peg near the right side of the fan.
      • Lightly pull the right edge of the heatsink away from the screen to release it from its recess in the frame.
      Demander à FixBot
    10. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the heatsink: étape 25, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Remove the heatsink: étape 25, image 2 de 2
      • Remove the heatsink.
      • Don't pull on the heatsink too hard, as the heat pipes bend easily. If you're having trouble, gently wiggle the heatsink.
      Demander à FixBot
    11. Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Reapply thermal paste: étape 26, image 1 de 2 Microsoft Surface Laptop 5 (15-inch) Heatsink and Fan Replacement, Reapply thermal paste: étape 26, image 2 de 2
      • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
      Demander à FixBot
Spencer Day
Membre depuis le 09/14/22
198 323 Réputation
1 243 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
51 360 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 35
Total : 868
