Aller au contenu principal
Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Prepare your laptop for disassembly: étape 1, image 3 de 3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Flip your laptop over: étape 2, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Flip your laptop over: étape 2, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Flip your laptop over: étape 2, image 3 de 3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the feet: étape 3, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the feet: étape 3, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the feet: étape 3, image 3 de 3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the lower case screws: étape 4, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the lower case screws: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Detach the lower case: étape 5, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Detach the lower case: étape 5, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Detach the lower case: étape 5, image 3 de 3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 6, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 6, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 6, image 3 de 3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the lower case: étape 7, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the lower case: étape 7, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the lower case: étape 7, image 3 de 3
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Disconnect the battery: étape 8, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Disconnect the battery: étape 8, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Disconnect the battery: étape 8, image 3 de 3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 9, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 9, image 2 de 2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 10, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 10, image 2 de 2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the battery: étape 11, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement, Remove the battery: étape 11, image 2 de 2
    • Use a Torx Plus 5IP screwdriver to remove the eight 5.4 mm‑long screws securing the battery.
    • Be very careful not to puncture the battery with your screwdriver.
  12. Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 12, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 12, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Battery Replacement: étape 12, image 3 de 3
    • Lift the battery and remove it.
    • If your battery is swollen, take appropriate precautions.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
Calibrate your newly installed battery after completing this guide.
Spencer Day
Membre depuis le 09/14/22
150 037 Réputation
995 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 648 tutoriels rédigés
3 commentaires de tutoriel
Anybody knows how to get the IP screw drivers? I just seem to find the Tork screwdrivers, but not the Tork + IP2 to 6 like it is recommended on the repair guide by Microsoft on YouTube.
Vibraille - Réponse
Hi Vibraille! We sell Torx Plus bits ''''on our site, as well as the driver to use them with.
Spencer Day -
Thanks Spencer Day for the information. They are very hard to find. They don't even come up with a simple search in the tool section and their names are not IP x, rather iFixit precision 4 mm, which could be anything. I also checked every kit (I think) and I couldn't find bits set with the IP screw drivers (torx plus) either.
Vibraille - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 46
30 derniers jours : 251
Total : 2,996
