Aller au contenu principal
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Microsoft Surface Laptop 7, utilisez notre manuel de réparation.
  1. Microsoft Surface Laptop 7 (13.8-inch) Chip ID, Main Board Side 1: étape 1, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Chip ID, Main Board Side 1: étape 1, image 2 de 2
    • Qualcomm X1P-64-100-103 Snapdragon X Plus deca-core applications processor
    • Micron MT62F1G32D2DS-023 WT:C 4 GB LPDDR5X SDRAM memory
    • Qualcomm PMC8380-001-00 power management
    • Qualcomm PMC8380VE-001 power management
    • Qualcomm PMC1010H-001-02 charge pump & buck regulator
    • Qualcomm PMC1010H-001-06 charge pump & buck regulator
    • Qualcomm power management
  2. Microsoft Surface Laptop 7 (13.8-inch) Chip ID: étape 2, image 1 de 1
    • Qualcomm SMB2360-002 battery charger
    • Qualcomm SMB2361-002 battery charger
    • Likely Qualcomm clock generator
    • Parade Technologies PS8830 USB4, DisplayPort 2.0, and Thunderbolt 3.0 retimer
    • Probably camera processor
    • Macronix MX25U1633FZUI 2 MB serial NOR flash memory
    • Likely Qualcomm camera power management
  3. Microsoft Surface Laptop 7 (13.8-inch) Chip ID: étape 3, image 1 de 1
    • Murata PE23108 LED backlight driver
    • Texas Instruments TPS61163A 2-ch. white LED driver
    • Analog Devices MAX34417 current & voltage monitor
    • Monolithic Power Systems MP2322 1 A synchronous step-down converter
    • Monolithic Power Systems DC-DC converter
    • NXP Semiconductors NX20P0407UK USB type-C port protector
  4. Microsoft Surface Laptop 7 (13.8-inch) Chip ID: étape 4, image 1 de 1
    • Nexperia 74LVC2G66 dual SPST analog switch
    • Monolithic Power Systems MP5077GG programmable load switch
    • Texas Instruments TPS22964C 3 A load switch
    • Diodes Incorporated AP22653AFDZ-7 adjustable current-limited power distribution switch
    • Diodes Incorporated AP22800HB-7 programmable load switch
    • Richtek LDO regulator
    • Texas Instruments PCA9306 2-bit voltage level translator
  5. Microsoft Surface Laptop 7 (13.8-inch) Chip ID: étape 5, image 1 de 1
    • Texas Instruments SN74LV1T08 single 2-input AND gate
    • Texas Instruments SN74LV1T32 single 2-input OR gate
    • Texas Instruments SN74AUP1G08 single 2-input AND gate
  6. Microsoft Surface Laptop 7 (13.8-inch) Chip ID, Main Board Side 1 - Connectivity: étape 6, image 1 de 1
    • Qualcomm WCN7851-501 FastConnect 7800 WiFi 7 & Bluetooth 5.4 controller
    • Qualcomm 2.4 GHz front-end module
    • Qualcomm 5 GHz front-end module
  7. Microsoft Surface Laptop 7 (13.8-inch) Chip ID, Main Board Side 1 - Filters: étape 7, image 1 de 1
    • Qualcomm B7530 Bluetooth/WLAN SAW filter
  8. Microsoft Surface Laptop 7 (13.8-inch) Chip ID, Main Board Side 2: étape 8, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Chip ID, Main Board Side 2: étape 8, image 2 de 2
    • NXP Semiconductors MIMXRT633SFFOB 32-bit ARM Cortex-M33 microcontroller w/ Xtensa HiFi4 audio DSP
    • Macronix MX25U51293GZ4I40 64 MB serial NOR flash memory
    • Qualcomm WCD9385-000 audio codec
    • Qualcomm audio amplifier
    • Renesas mixed signal array
    • Monolithic Power Systems MP28167GQ-A 3 A buck-boost converter
  9. Microsoft Surface Laptop 7 (13.8-inch) Chip ID: étape 9, image 1 de 1
    • Richtek RT5753ALGQW 3 A synchronous step-down converter
    • Richtek RT5788AGJ8F 4 A synchronous step-down converter
    • Analog Devices MAX4983EEVB+ USB 2.0 DPDT analog switch
    • Vishay DG2723 dual SPDT analog switch
    • onsemi FPF2495CUCX 28 V over-voltage & over-current protection load switch
    • onsemi FPF1504 load management switch
  10. Microsoft Surface Laptop 7 (13.8-inch) Chip ID: étape 10, image 1 de 1
    • Nexperia 74AVC2T245 2-bit level shifter
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 39
30 derniers jours : 223
Total : 5,750
