Aller au contenu principal
Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: étape 1, image 3 de 3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: étape 2, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: étape 2, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: étape 2, image 3 de 3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: étape 3, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: étape 3, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: étape 3, image 3 de 3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case screws: étape 4, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case screws: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: étape 5, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: étape 5, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: étape 5, image 3 de 3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 6, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 6, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 6, image 3 de 3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: étape 7, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: étape 7, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: étape 7, image 3 de 3
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: étape 8, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: étape 8, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: étape 8, image 3 de 3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 9, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 9, image 2 de 2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 10, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 10, image 2 de 2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: étape 11, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: étape 11, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: étape 11, image 3 de 3
    • The left speaker will be on your right-hand side, since the laptop is laying upside down.
    • Slide the point of a spudger under the left speaker connector and gently lift it straight up and out of the socket.
    • Don't lift on the cables themselves, or you may damage them.
    • During reassembly, hold the connector over its socket and press down gently with the flat end of a spudger until it clicks into place. If you're having trouble, don't try to force the connector into its socket—reposition it and try again.
  12. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the speaker: étape 12, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the speaker: étape 12, image 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 3.2 mm‑long screws securing the left speaker.
  13. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 13, image 1 de 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: étape 13, image 2 de 2
    • Remove the speaker.
    • During reassembly, place the speaker onto the frame so the grommets on the right edge go over their screw posts.
  14. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: étape 14, image 1 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: étape 14, image 2 de 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: étape 14, image 3 de 3
    • Make sure your replacement speaker has two rubber grommets installed on its right edge.
    • If it doesn't, remove the grommets from your old speaker and install them in your replacement.
    • Installing these can be tricky. Use your fingers to pinch the grommet and slide it into its notch.
Spencer Day
Membre depuis le 09/14/22
150 212 Réputation
995 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 648 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 24
Total : 384
