Aller au contenu principal
Microsoft Surface Pen Tip Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Pen Tip Replacement, Tip: étape 1, image 1 de 3 Microsoft Surface Pen Tip Replacement, Tip: étape 1, image 2 de 3 Microsoft Surface Pen Tip Replacement, Tip: étape 1, image 3 de 3
    • Order the Microsoft Surface Pen tip replacement kit.
    • Hold your pen at an angle and unscrew the top part of the pen.
  2. Microsoft Surface Pen Tip Replacement: étape 2, image 1 de 3 Microsoft Surface Pen Tip Replacement: étape 2, image 2 de 3 Microsoft Surface Pen Tip Replacement: étape 2, image 3 de 3
    • Extract the tip now that it is fully exposed.
    • When you extract the tip, make sure don't do it too hard. The inside of the pen can be broken.
  3. Microsoft Surface Pen Tip Replacement: étape 3, image 1 de 3 Microsoft Surface Pen Tip Replacement: étape 3, image 2 de 3 Microsoft Surface Pen Tip Replacement: étape 3, image 3 de 3
    • After you extract the tip, roll the tissue on toothpick.
    • I recommend cutting the tissue in half.
  4. Microsoft Surface Pen Tip Replacement: étape 4, image 1 de 3 Microsoft Surface Pen Tip Replacement: étape 4, image 2 de 3 Microsoft Surface Pen Tip Replacement: étape 4, image 3 de 3
    • Clean the inside of the top detachable part of the pen with a toothpick covered with tissue.
    • Make sure there is no residue on the edge.
  5. Microsoft Surface Pen Tip Replacement: étape 5, image 1 de 3 Microsoft Surface Pen Tip Replacement: étape 5, image 2 de 3 Microsoft Surface Pen Tip Replacement: étape 5, image 3 de 3
    • Choose the tip that you would like to use and insert in a hole.
  6. Microsoft Surface Pen Tip Replacement: étape 6, image 1 de 3 Microsoft Surface Pen Tip Replacement: étape 6, image 2 de 3 Microsoft Surface Pen Tip Replacement: étape 6, image 3 de 3
    • Screw the detachable part of the pen back on.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 69
Total : 5,940
