Aller au contenu principal
Microsoft Surface Pro X SSD and SIM Card Door Removal
Ce dont vous avez besoin
  1. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: étape 1, image 1 de 2 Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: étape 1, image 2 de 2
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: étape 2, image 1 de 2 Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: étape 2, image 2 de 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X SSD and SIM Card Door Removal, Remove the SSD and SIM card door: étape 3, image 1 de 1
Adam O'Camb
Membre depuis le 04/11/15
198 479 Réputation
416 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 31
30 derniers jours : 160
Total : 9,720
