Aller au contenu principal
Microsoft Zune HD Lower Rear Panel Replacement
Ce dont vous avez besoin
  1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: étape 1, image 1 de 1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Lower Rear Panel Replacement: étape 2, image 1 de 2 Microsoft Zune HD Lower Rear Panel Replacement: étape 2, image 2 de 2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: étape 3, image 1 de 2 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: étape 3, image 2 de 2
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Lower Rear Panel Replacement: étape 4, image 1 de 1
    • Carefully slide the lower rear panel away from the Zune.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 3,114
