Aller au contenu principal
Midea MRU03M2ABB Upright Freezer Door Replacement
Ce dont vous avez besoin
  1. Midea MRU03M2ABB Upright Freezer Door Replacement, Door: étape 1, image 1 de 2 Midea MRU03M2ABB Upright Freezer Door Replacement, Door: étape 1, image 2 de 2
    • Unplug the device.
    • Only unplug when your hand is dry.
  2. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 2, image 1 de 1
    • Empty the shelves.
  3. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 3, image 1 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 3, image 2 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 3, image 3 de 3
    • Use a plastic spatula to remove the hinge cover on top of the freezer.
    • Pushing at the pointy part of the cover makes it easier to remove.
  4. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 4, image 1 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 4, image 2 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 4, image 3 de 3
    • Unscrew the hinge counterclockwise.
  5. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 5, image 1 de 2 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 5, image 2 de 2
    • Lift the hinge out of the freezer and the door.
  6. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 6, image 1 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 6, image 2 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 6, image 3 de 3
    • With two hands, gently hold and open the door as usual.
    • Lift the door up to remove it from the bottom hinge.
    • You have completely detached the door from the freezer.
  7. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 7, image 1 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 7, image 2 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 7, image 3 de 3
    • With the new door, locate the hole underneath the door.
    • Using two hands, gently place the door on top of the hinge (the pointy part of the hinge should fit inside the hole).
    • Close the door.
  8. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 8, image 1 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 8, image 2 de 3 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 8, image 3 de 3
    • Use your hand to align the door so these three screw holes stay on the same line.
    • Carefully place the top hinge to fit these holes.
  9. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 9, image 1 de 2 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 9, image 2 de 2
    • Thread and tighten the screws clockwise.
    • Gently swing the door to make sure it operates well.
  10. Midea MRU03M2ABB Upright Freezer Door Replacement: étape 11, image 1 de 2 Midea MRU03M2ABB Upright Freezer Door Replacement: étape 11, image 2 de 2
    • Finally, firmly press the cover onto the hinge to secure it. Now, you have completely replaced the door.
    • A "click" will indicate that the cover is finally in its place.
Ligne d'arrivée
Thinh Lang
Membre depuis le 01/16/24
193 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-31, O'Regan Winter 2024 Membre de l'équipe York University, Team 1-31, O'Regan Winter 2024
YORK-O'REGAN-W24S1G31
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 25
Total : 113
