Aller au contenu principal
Midland X-tra Talk Radio LXT118 Antenna Replacement
Ce dont vous avez besoin
  1. Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: étape 1, image 1 de 2 Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: étape 1, image 2 de 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Antenna Replacement: étape 2, image 1 de 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Antenna Replacement, Case: étape 3, image 1 de 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Antenna Replacement: étape 4, image 1 de 1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Antenna Replacement, Antenna: étape 5, image 1 de 1
    • Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
  6. Midland X-tra Talk Radio LXT118 Antenna Replacement: étape 6, image 1 de 1
    • Check the connection of the antenna with your eyes and fingers. The connection should be firm and smooth where it was soldered.
    • Ensure that the spring of the antenna isn't crooked or damaged by rubbing your fingers along the length of the spring.
    • Desolder the connection of the antenna to the motherboard. Careful!, if used improperly, the soldering tool can damage the circuit board!
  7. Midland X-tra Talk Radio LXT118 Antenna Replacement: étape 7, image 1 de 1
    • After obtaining a new or undamaged spring, solder it back onto the circuit board. Again, this is a delacate process as the soldering tool will be hot!
5 autres ont terminé cette réparation.
Andre Nguyen
Membre depuis le 01/18/13
108 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 19-43, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 18
Total : 2,097
