Aller au contenu principal
Midland X-tra Talk Radio LXT118 Speaker Replacement
Ce dont vous avez besoin
  1. Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: étape 1, image 1 de 2 Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: étape 1, image 2 de 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Speaker Replacement: étape 2, image 1 de 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Speaker Replacement, Case: étape 3, image 1 de 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Speaker Replacement: étape 4, image 1 de 1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: étape 5, image 1 de 1
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  6. Midland X-tra Talk Radio LXT118 Speaker Replacement: étape 6, image 1 de 1
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Midland X-tra Talk Radio LXT118 Speaker Replacement: étape 7, image 1 de 1
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Midland X-tra Talk Radio LXT118 Speaker Replacement: étape 8, image 1 de 1
    • The speaker is now disassembled!
  9. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: étape 9, image 1 de 1
    • Solder the new wires to the circuit board in the spots denoted by the two red circles.
  10. Midland X-tra Talk Radio LXT118 Speaker Replacement: étape 10, image 1 de 1
    • Place the speaker back inside the shell casing in the same way that it was originally placed.
    • Accurately use a polyurethane glue around the rim of the speaker to mount it firmly back inside the plastic casing.
2 autres ont terminé cette réparation.
James Tucker Dunn
Membre depuis le 01/18/13
371 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 19-43, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 12
Total : 769
