Aller au contenu principal
Milwaukee 2780-20 (2) Ball Bearings Replacement
Ce dont vous avez besoin
  1. Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: étape 1, image 1 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: étape 1, image 2 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: étape 1, image 3 de 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 2, image 1 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 2, image 2 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 2, image 3 de 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 3, image 1 de 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 4, image 1 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 4, image 2 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 4, image 3 de 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: étape 5, image 1 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: étape 5, image 2 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: étape 5, image 3 de 3
    • Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
  6. Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 6, image 1 de 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 6, image 2 de 2
    • Pull the gearcase away from electronic assembly to expose the inside.
  7. Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 7, image 1 de 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 7, image 2 de 2
    • Using a 3/8 Wrench, Remove the nut located in the center of the Gearcase.
    • The nut and pinion should immediatley come apart from the rotor assembly.
  8. Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 8, image 1 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 8, image 2 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 8, image 3 de 3
    • Pull the rotor assembly apart from the gearcase casing.
  9. Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 9, image 1 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 9, image 2 de 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 9, image 3 de 3
    • Using a Torx T15 screwdriver, remove the two 4mm screws to take the bearing retainer off.
  10. Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 10, image 1 de 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: étape 10, image 2 de 2
    • Use a hammer to knock out the bearing and begin installing the new one before reassembling.
Chris Hopper
Membre depuis le 08/22/19
468 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 39
Total : 2,994
