Introduction
Do you know what happens when your grinder overheats? If not, this is a quick guide on how to change the ball bearings. A ball bearing is a ring consisting of small solid metal balls between a wheel and a fixed axle, in which the rotating parts and stationary parts are separated to reduce friction. A damaged or worn ball bearing will reduce the performance of your grinder and ultimately destroy it completely.
Ce dont vous avez besoin
Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
