Aller au contenu principal
Milwaukee 2780-20 Trigger Assembly Replacement
Ce dont vous avez besoin
  1. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: étape 1, image 1 de 3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: étape 1, image 2 de 3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: étape 1, image 3 de 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 Trigger Assembly Replacement: étape 2, image 1 de 3 Milwaukee 2780-20 Trigger Assembly Replacement: étape 2, image 2 de 3 Milwaukee 2780-20 Trigger Assembly Replacement: étape 2, image 3 de 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 Trigger Assembly Replacement: étape 3, image 1 de 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 Trigger Assembly Replacement: étape 4, image 1 de 3 Milwaukee 2780-20 Trigger Assembly Replacement: étape 4, image 2 de 3 Milwaukee 2780-20 Trigger Assembly Replacement: étape 4, image 3 de 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
Chris Hopper
Membre depuis le 08/22/19
468 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 22
Total : 1,184
