Aller au contenu principal
Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement
Ce dont vous avez besoin
  1. Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement, Back Panel: étape 1, image 1 de 1
    • Orient your saw sideways so that the blade is facing downwards.
  2. Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement: étape 2, image 1 de 3 Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement: étape 2, image 2 de 3 Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement: étape 2, image 3 de 3
    • Remove the nine 6 mm screws using a Torx T4 screwdriver.
    • Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
    • Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
  3. Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement, Switch: étape 3, image 1 de 2 Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement, Switch: étape 3, image 2 de 2
    • Take the start switch out of the device gently without moving any other hardware.
  4. Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement: étape 4, image 1 de 2 Milwaukee Circular Saw 263020 B57A 2008 Switch Replacement: étape 4, image 2 de 2
    • Carefully pull the spring underneath the switch away from the switch.
Ahmed Altawami
Membre depuis le 09/12/23
473 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 140
