Aller au contenu principal
Milwaukee Hackzall 2625-20 Motor Replacement
Ce dont vous avez besoin
  1. Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: étape 1, image 1 de 2 Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: étape 1, image 2 de 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Motor Replacement, Electric Motor: étape 2, image 1 de 1
    • Find the red and black wire running from the back of the motor to the trigger mechanism.
    • With a soldering iron remove the two solders on the trigger mechanism.
  3. Milwaukee Hackzall 2625-20 Motor Replacement: étape 3, image 1 de 2 Milwaukee Hackzall 2625-20 Motor Replacement: étape 3, image 2 de 2
    • Remove the two screws connecting the motor to the gear box with a T15 torx screwdriver.
    • The motor is now free and can be removed from the tool.
Mason Jones
Membre depuis le 09/18/19
572 Réputation
5 tutoriels rédigés
Équipe
2 commentaires
Is there any chance to change only brushes in this motor?
Marcin Kędzior - Réponse
That’s my exact question as well, nobody seems to cover this..
Anthony DeSanto - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 40
Total : 2,419
