Aller au contenu principal
Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement
Ce dont vous avez besoin
  1. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: étape 1, image 1 de 2 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: étape 1, image 2 de 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: étape 2, image 1 de 2 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: étape 2, image 2 de 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Forward/Reverse Switch: étape 3, image 1 de 1
    • Gently move the trigger assembly out of the way and remove the switch from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 26
Total : 1,751
