Aller au contenu principal
Milwaukee Hex Impact Driver 2656-20 Trigger Assembly Replacement
Ce dont vous avez besoin
  1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: étape 1, image 1 de 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: étape 1, image 2 de 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: étape 2, image 1 de 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: étape 2, image 2 de 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: étape 3, image 1 de 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: étape 3, image 2 de 2
    • Remove the two 6 mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
    • Move the two wires out of the way.
  4. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: étape 4, image 1 de 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: étape 4, image 2 de 2
    • Gently pull up on the trigger assembly to remove it from the case.
  5. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: étape 5, image 1 de 1
    • Remove the trigger assembly from the device.
Troy Conrad
Membre depuis le 09/16/19
97 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 36
Total : 1,184
