Aller au contenu principal
Milwaukee Hex Impact Driver 2750-20 Output Shaft Bearing Replacement
Ce dont vous avez besoin
  1. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Outer Casing: étape 1, image 1 de 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: étape 2, image 1 de 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Output Shaft Bearing: étape 3, image 1 de 1
    • Once the interior is open locate the output shaft driver pictured at the left of the screen.
  4. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: étape 4, image 1 de 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: étape 4, image 2 de 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: étape 4, image 3 de 3
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
  5. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: étape 5, image 1 de 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: étape 5, image 2 de 3 Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the fan and the drive shaft assembly from the motor core assembly.
    • Using a pair of tweezers, remove the retaining ring.
    • Remove the old bearing and reinstall the new retaining clip.
Charles Putnam
Membre depuis le 02/12/19
409 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 587
