Aller au contenu principal
Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement
Ce dont vous avez besoin
  1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: étape 1, image 1 de 1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: étape 2, image 1 de 2 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: étape 2, image 2 de 2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: étape 3, image 1 de 2 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: étape 3, image 2 de 2
    • Locate the black forward/reverse button underneath the chuck.
    • Pull the button gently towards you to remove it from the trigger assembly.
  4. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: étape 4, image 1 de 1
    • Using replacement part NO. 45-24-D013 (forward/reverse shuttle), follow the steps of this guide in reverse order.
Alex Larson
Membre depuis le 01/16/19
243 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 720
