Aller au contenu principal
Milwaukee Hex Impact Driver 2753-20 Trigger Replacement
Ce dont vous avez besoin
  1. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: étape 1, image 1 de 2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: étape 1, image 2 de 2
    • While pinching the red locking buttons, pull the battery away from the front of the drill until the battery is fully removed.
    • The battery is missing from this device so its removal is being mimed.
  2. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: étape 2, image 1 de 1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  3. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: étape 3, image 1 de 2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: étape 3, image 2 de 2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  4. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: étape 4, image 1 de 2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: étape 4, image 2 de 2
    • Lift the trigger assembly from the device. It is connected to the circuit board by wires.
    • Carefully desolder the wires off of the trigger assembly using a soldering iron on medium heat.
    • Refer to this guide for proper desoldering technique.
  5. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: étape 5, image 1 de 1
    • Remove the trigger assembly from the device.
    • Replace old trigger assembly with replacement part no. 14-20-0013.
Alex Larson
Membre depuis le 01/16/19
243 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 46
Total : 4,527
