Aller au contenu principal
Milwaukee Impact Wrench 9070-20 Motor Field Winding Replacement
Ce dont vous avez besoin
  1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: étape 1, image 1 de 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: étape 1, image 2 de 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: étape 1, image 3 de 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 2, image 1 de 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 2, image 2 de 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 2, image 3 de 3
    • Remove the four screws on each corner of the gear box assembly using a T-20 Screwdriver.
    • Use a plastic opening tool, slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 3, image 1 de 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 3, image 2 de 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 3, image 3 de 3
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The motor brushes may need to be compressed to help with the removal of the gearbox assembly.
  4. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 4, image 1 de 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 4, image 2 de 3 Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 4, image 3 de 3
    • Disconnect the black AC wire from the brown field wire.
    • Disconnect the black field wire from the switch.
  5. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: étape 5, image 1 de 1
    • Pull straight up on the field winding to remove it from the body.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 16
Total : 375
