Aller au contenu principal
Milwaukee Impact Wrench 9070-20 Power Cord Replacement
Ce dont vous avez besoin
  1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: étape 1, image 1 de 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: étape 1, image 2 de 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: étape 1, image 3 de 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using the T20 Torx screwdriver.
    • Remove the four 14mm screws using the same screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 2, image 1 de 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 2, image 2 de 3 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 2, image 3 de 3
    • Hold the device so the gray part faces directly towards you.
    • Remove the four screws on the sides using the T20 Torx screwdriver.
    • After removing all screws, use a small plastic pry bar to slide the gearbox assembly forward slightly.
  3. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 3, image 1 de 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 3, image 2 de 2
    • Gently remove the upper clam shell from the device.
    • Lift a black colored power cord from its mount at the bottom of the device, so it can move freely.
  4. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 4, image 1 de 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 4, image 2 de 2
    • Disconnect the brown field winding wire from the white ac power cord wire.
  5. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 5, image 1 de 2 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: étape 5, image 2 de 2
    • Disconnect the black ac power wire from the connector on the bottom of the forward / reverse switch.
    • Remove the AC power cord and replace it with a new one.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 17
Total : 361
