Aller au contenu principal
Milwaukee M12 2407-20 Speed Selector Lever Replacement
Ce dont vous avez besoin
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: étape 1, image 1 de 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: étape 2, image 1 de 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: étape 3, image 1 de 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: étape 3, image 2 de 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: étape 3, image 3 de 3
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: étape 4, image 1 de 1
    • Use a spudger to pry the broken speed selector lever off the assembly.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 15
Total : 1,567
