Aller au contenu principal
Milwaukee M18 2606-20 Chuck Replacement
Ce dont vous avez besoin
  1. Milwaukee M18 2606-20 Chuck Replacement, Chuck: étape 1, image 1 de 3 Milwaukee M18 2606-20 Chuck Replacement, Chuck: étape 1, image 2 de 3 Milwaukee M18 2606-20 Chuck Replacement, Chuck: étape 1, image 3 de 3
    • Rotate the chuck counterclockwise as far as possible to loosen from the base.
  2. Milwaukee M18 2606-20 Chuck Replacement: étape 2, image 1 de 2 Milwaukee M18 2606-20 Chuck Replacement: étape 2, image 2 de 2
    • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
    • Rotate the screw clockwise to loosen it.
    • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
  3. Milwaukee M18 2606-20 Chuck Replacement: étape 3, image 1 de 2 Milwaukee M18 2606-20 Chuck Replacement: étape 3, image 2 de 2
    • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
    • The Allen wrench will be used for leverage when removing the chuck.
    • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
  4. Milwaukee M18 2606-20 Chuck Replacement: étape 4, image 1 de 3 Milwaukee M18 2606-20 Chuck Replacement: étape 4, image 2 de 3 Milwaukee M18 2606-20 Chuck Replacement: étape 4, image 3 de 3
    • Rotate the Allen wrench counterclockwise to remove the chuck.
2 autres ont terminé cette réparation.
4 commentaires
Milwaukee say to heat the tort screw up to loosen the locktite. Did this to the second chuck I replaced came off much easier. Getting the chuck off was a different story, tried hitting a 10mm allan key in the chuck didn’t work. Ended up getting a 10mm 1/2’ allan head socket on a breaker bar. Put the drill on the ground stood on it and with the other leg kicked the breaker bar. Came straight off.
tim.karen.collins - Réponse
My chuck was stuck and working rough, needed to get it off the drill motor. Worked on a Harbor Freight Hercules 1/2” hammer/drill just fine. Neat trick using the Allen for leverage! Looks a lot like a copy…
Thanks! Dave D.
David Dryden - Réponse
Not really clear in what mode it needs to be, nor what rotation mode
Rombout Versluijs - Réponse
1st gear and twist the drill threshold to the drill bit setting (max torque).
Dustin Gordon -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 42
30 derniers jours : 243
Total : 18,176
