Aller au contenu principal
Minn Kota Trolling Motor Propeller Replacement
Ce dont vous avez besoin
  1. Minn Kota Trolling Motor Propeller Replacement, Propeller: étape 1, image 1 de 1
    • Clean the propeller and surrounding area so that you’re working with clean materials. This can also help loosen bolts, and make it easier to take apart.
    • Make sure that the trolling motor is disconnected from any power source.
  2. Minn Kota Trolling Motor Propeller Replacement: étape 2, image 1 de 2 Minn Kota Trolling Motor Propeller Replacement: étape 2, image 2 de 2
    • Remove the locking nut by turning in a counterclockwise motion.
  3. Minn Kota Trolling Motor Propeller Replacement: étape 3, image 1 de 2 Minn Kota Trolling Motor Propeller Replacement: étape 3, image 2 de 2
    • Once you've unscrewed the propeller nut, you must also remove the lock washer located directly beneath.
    • If you purchased a new propeller kit, you may replace the old lock washer with the new washer you received in your kit.
  4. Minn Kota Trolling Motor Propeller Replacement: étape 4, image 1 de 3 Minn Kota Trolling Motor Propeller Replacement: étape 4, image 2 de 3 Minn Kota Trolling Motor Propeller Replacement: étape 4, image 3 de 3
    • Remove the drive pin by pushing on either side so it slides out.
  5. Minn Kota Trolling Motor Propeller Replacement: étape 5, image 1 de 1
    • When reinstalling your new propeller, make sure to properly align the drive pin with the base of the new propeller.
Once you have the drive pin lined up correctly with the base of the propeller, repeat steps 1-3 in reverse order. Make sure to utilize your new parts such as the drive pin and lock washer if you purchased a propeller replacement kit to replace your old hardware.
2 autres ont terminé cette réparation.
Jacob Fowler
Membre depuis le 02/22/18
175 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 34
Total : 5,437
