Introduction
This guide disassembles the capture button, so the device can be checked for a broken spring or for debris blocking its movement.
Pièces
Aucune pièce nécessaire.
Locate and remove the silver screws on each side of the camera.
  • Locate and remove the silver screws on each side of the camera.
  • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
Ajouter un commentaire
Then, carefully pry apart the front and back outer casing away from the internal components.
  • Then, carefully pry apart the front and back outer casing away from the internal components.
  • Be aware of the ribbon wire that will disconnect when the casing is detached.
  • Choosing the front half of the casing, locate the capture button on the top.
  • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
  • The button will spring free. The capture device consists of the plastic button and a small metal spring.
  • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
Membre depuis le 11/03/2013
28 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 12-4, Benson Spring 2013 Membre de l'équipe Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 251
