Introduction
The outer casing of the camera is the first step to fixing any internal hardware. It is essential that the outer casing is in proper condition and not damaged to ensure the integrity of the internal components.
Pièces
Aucune pièce nécessaire.
Locate and remove the silver screws on each side of the camera.
  • Locate and remove the silver screws on each side of the camera.
  • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
Ajouter un commentaire
Then, carefully pry apart the front and back outer casing away from the internal components.
  • Then, carefully pry apart the front and back outer casing away from the internal components.
  • Be aware of the ribbon wire that will disconnect when the casing is detached.
To reassemble your device, follow these instructions in reverse order. The outer casing must be properly in place and screws tight to protect the internal hardware.
Megan Milam
Membre depuis le 11/03/2013
28 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 12-4, Benson Spring 2013 Membre de l'équipe Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 225
