Introduction
The flashbulb and casing are one component located at the top of the camera. A replacement will be the whole component and not each of the parts separately.
Pièces
Aucune pièce nécessaire.
Locate and remove the silver screws on each side of the camera.
  • Locate and remove the silver screws on each side of the camera.
  • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
Ajouter un commentaire
Then, carefully pry apart the front and back outer casing away from the internal components.
  • Then, carefully pry apart the front and back outer casing away from the internal components.
  • Be aware of the ribbon wire that will disconnect when the casing is detached.
  • Remove 2mm screws connecting the flash housing to the main components of the camera.
  • Use a Philips #00 screwdriver to remove the black 2.0mm (4 instances) screws .
  • Use the spudger to push the black plastic hooks through the circuit board to release the flash housing.
  • Once the screws have been removed, pull the circuit board away from the body of the camera.
  • Wires will keep it from completely detaching.
  • Pull the housing away from the circuit board.
To reassemble device, follow steps in reverse order. This will require the reattachment of wires from the camera to the flashbulb casing.
Keith Sechrist
Membre depuis le 11/03/2013
22 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 12-4, Benson Spring 2013 Membre de l'équipe Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 298
