Aller au contenu principal
Minolta Maxxum QTSI Tripod Mount Replacement
Ce dont vous avez besoin
  1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: étape 1, image 1 de 1
    • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
  2. Minolta Maxxum QTSI Tripod Mount Replacement: étape 2, image 1 de 2 Minolta Maxxum QTSI Tripod Mount Replacement: étape 2, image 2 de 2
    • Once all the screws are removed, the panel should easily come off.
    • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
    • Pull the bottom panel towards you, it should come off easily.
  3. Minolta Maxxum QTSI Tripod Mount Replacement: étape 3, image 1 de 1
    • The tripod socket is visible when the bottom panel is removed.
    • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
    • When the screws are removed, the tripod socket is free and can easily be lost.
  4. Minolta Maxxum QTSI Tripod Mount Replacement: étape 4, image 1 de 2 Minolta Maxxum QTSI Tripod Mount Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to gently remove the tripod socket, and replace it.
Jordan Ellery
Membre depuis le 10/10/16
388 Réputation
3 tutoriels rédigés
Équipe
Sam Houston State, Team 12-4, Blackburne Fall 2016 Membre de l'équipe Sam Houston State, Team 12-4, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 9
Total : 384
