Introduction
If your viewfinder is cracked or dirty, you may need to access or replace it.
In order to access the viewfinder, the top panel needs to be taken off first. Once the top is removed, the rest of the replacement is relatively simple.
Ce dont vous avez besoin
Use the edge of a coin to twist open the battery compartment on the bottom of the camera. (Twist counterclockwise)
Remove the black Phillips #00 5mm screw at the bottom of the battery chamber.
Starting beneath the "SPOT" button, use the round side of the metal spudger and firmly pry underneath the grey top panel of the camera. Work your way counterclockwise around the camera prying at different spots until the top panel starts to come loose. Pry all the way around until you reach the "STsi" logo.
Remove the two black Phillips #00 5.0 mm screws on the viewfinder panel to take off the viewfinder.
