Aller au contenu principal
Minolta QTsi Maxxum Eyelet Straps Replacement
Ce dont vous avez besoin
  1. Minolta QTsi Maxxum Eyelet Straps Replacement, Eyelet Straps: étape 1, image 1 de 1
    • The battery compartment is located on the bottom panel of the camera.
    • Use a coin to open the battery compartment of the camera.
    • Twist the coin counterclockwise in order to release the latch.
  2. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 2, image 1 de 1
    • Once the compartment is open, grab the batteries and pull them out of the compartment.
    • There should be two batteries inside the battery compartment.
  3. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 3, image 1 de 1
    • With a screwdriver, remove the (7) black Phillips #00 5mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
    • Once all the screws are removed, the panel should easily come off.
  4. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 4, image 1 de 1
    • Once the bottom panel is removed, the one screw at the bottom of the battery compartment should be visible.
    • Remove the (1) black Phillips #00 5mm screw from the battery compartment.
  5. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 5, image 1 de 1
    • Press the release button on the side panel to pop open the back piece of the camera.
  6. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 6, image 1 de 1
    • Once the back panel is open, the chamber containing one screw should be visible.
    • Remove the (1) black Phillips #00 5mm screw inside.
  7. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 7, image 1 de 2 Minolta QTsi Maxxum Eyelet Straps Replacement: étape 7, image 2 de 2
    • Take out the (2) Phillips #00 5mm screws on the right side panel of the camera.
    • Remove the (1) Phillips #00 5mm screw on the left side panel of the camera.
    • Remove the side panels from the camera and set them aside .
    • Be careful when removing side panels. There is a plastic piece and spring underneath the left side panel that could get lost.
  8. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 8, image 1 de 1
    • When looking at the back of the camera, there should be a single screw on each side of the viewfinder.
    • Remove these (2) silver Phillips #00 5mm screws from each side of the viewfinder.
  9. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 9, image 1 de 1
    • When looking at the top of the camera, the flash hood is visible.
    • Lift the flash hood and remove the (1) silver Phillips #00 5mm screw.
  10. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 10, image 1 de 2 Minolta QTsi Maxxum Eyelet Straps Replacement: étape 10, image 2 de 2
    • The top panel of the camera should now be easy to pop off. If it is not, make sure that all screws listed in steps 3-9 are removed.
    • Lift the top panel away from the rest of the camera.
    • Be careful when removing the top panel because there are wires connected to it.
  11. Minolta QTsi Maxxum Eyelet Straps Replacement: étape 11, image 1 de 1
    • Once all parts of the camera are removed, both eyelet straps should be visible on the top left and right sides.
    • Unscrew the (4) black Phillips #00 5mm screws to remove each eyelet strap holder and replace them.
3 autres ont terminé cette réparation.
Maya Van Londen
Membre depuis le 10/10/16
315 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 12-4, Blackburne Fall 2016 Membre de l'équipe Sam Houston State, Team 12-4, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 378
