Introduction
Replacing the battery is a very simple task which only requires a spare coin and replacement battery.
Ce dont vous avez besoin
Flip the camera so that the bottom is facing you.
Take a spare coin and unscrew the battery cover off.
Remove the batteries, making sure to note their proper alignment.
Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
4 autres ont terminé cette réparation.
Un commentaire
Hi there, i'm a bit stuck, in my 35mm SLR i was taking a shot and the batteries died, leaving the mirror stuck in the up position, i've changed the batteries and the release for the shutter won't click, i can't advance the film lever and so it's a sitting duck at the moment. They're brand new batteries but because the mirror is up i can't even see if the metering works. because i'm half way through a roll of film i don't want to open the back and ruin it so i'm wondering if there's any way to get the shutter to release again or to get the mirror back down, i don't mind loosing a few blank exposures but again i really wouldn't want to ruin the film. Many thanks and i hope you can get back to me,
Cameron
