Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MistAire Humidifier Cap Spring Replacement
Ce dont vous avez besoin
    1. MistAire Humidifier Cap Spring Replacement, Cap Spring: étape 1, image 1 de 2 MistAire Humidifier Cap Spring Replacement, Cap Spring: étape 1, image 2 de 2
      • Lift the blue tank off of the base of the humidifier.
      • The two parts are not attached or snapped together, so they should separate easily.
      Demander à FixBot
      Ajouter un commentaire
    2. MistAire Humidifier Cap Spring Replacement: étape 2, image 1 de 3 MistAire Humidifier Cap Spring Replacement: étape 2, image 2 de 3 MistAire Humidifier Cap Spring Replacement: étape 2, image 3 de 3
      • Turn the tank upside down.
      • Turn the round cap counterclockwise to completely unscrew it.
      Demander à FixBot
    3. MistAire Humidifier Cap Spring Replacement: étape 3, image 1 de 2 MistAire Humidifier Cap Spring Replacement: étape 3, image 2 de 2
      • There is a white plastic rod that goes through the center of the cap. It has a flat, circular end and a pointed end. The pointed end has a small, blue, silicone ring around it.
      • Push the flat side of the rod until the pointed end protrudes from the other side of the cap.
      Demander à FixBot
    4. MistAire Humidifier Cap Spring Replacement: étape 4, image 1 de 3 MistAire Humidifier Cap Spring Replacement: étape 4, image 2 de 3 MistAire Humidifier Cap Spring Replacement: étape 4, image 3 de 3
      • While still pushing on the rod, tug the small, blue, silicone ring completely off of the pointed end.
      Demander à FixBot
    5. MistAire Humidifier Cap Spring Replacement: étape 5, image 1 de 2 MistAire Humidifier Cap Spring Replacement: étape 5, image 2 de 2
      • Once the ring is off, pull the rod and spring out from the center of the cap.
      Demander à FixBot
    6. MistAire Humidifier Cap Spring Replacement: étape 6, image 1 de 2 MistAire Humidifier Cap Spring Replacement: étape 6, image 2 de 2
      • Slide the broken spring off of the rod.
      • The spring should come off easily.
      Demander à FixBot
    7. MistAire Humidifier Cap Spring Replacement: étape 7, image 1 de 2 MistAire Humidifier Cap Spring Replacement: étape 7, image 2 de 2
      • Slide a new 10x6x19mm Tapered Compression Spring around the rod.
      • Ensure the narrower end of the cone-shaped spring goes first.
      Demander à FixBot
    8. MistAire Humidifier Cap Spring Replacement: étape 8, image 1 de 2 MistAire Humidifier Cap Spring Replacement: étape 8, image 2 de 2
      • Pinch the spring gently to secure it around the rod.
      • Push the pointed end of the rod all the way through the center hole of the cap. Hold it there for Step 9.
      Demander à FixBot
    9. MistAire Humidifier Cap Spring Replacement: étape 9, image 1 de 3 MistAire Humidifier Cap Spring Replacement: étape 9, image 2 de 3 MistAire Humidifier Cap Spring Replacement: étape 9, image 3 de 3
      • Push the small blue ring back onto the pointed end of the rod.
      • You should hear a snap when it’s secured.
      Demander à FixBot
    10. MistAire Humidifier Cap Spring Replacement: étape 10, image 1 de 3 MistAire Humidifier Cap Spring Replacement: étape 10, image 2 de 3 MistAire Humidifier Cap Spring Replacement: étape 10, image 3 de 3
      • Now that you have fixed the spring-loaded cap, screw the cap clockwise back onto the bottom of the tank.
      Demander à FixBot
    11. MistAire Humidifier Cap Spring Replacement: étape 11, image 1 de 3 MistAire Humidifier Cap Spring Replacement: étape 11, image 2 de 3 MistAire Humidifier Cap Spring Replacement: étape 11, image 3 de 3
      • Place the tank back onto the humidifier base.
      • You have now successfully replaced the spring in the MistAire Humidifier!
      Demander à FixBot
Ligne d'arrivée
Abby
Membre depuis le 01/31/24
193 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-1, Andersen Winter 2024 Membre de l'équipe UC Davis, Team 1-1, Andersen Winter 2024
UCD-ANDERSEN-W24S1G1
3 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 72
Total : 1,649
