Aller au contenu principal
Mitsubishi Electric DD-6040 Power Button Replacement
Ce dont vous avez besoin
  1. Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: étape 1, image 1 de 3 Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: étape 1, image 2 de 3 Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: étape 1, image 3 de 3
    • Unplug your DVD player prior to working on the device.
    • Remove five 1.2 mm Phillips #1 screws to disassemble the DVD player.
  2. Mitsubishi Electric DD-6040 Power Button Replacement: étape 2, image 1 de 3 Mitsubishi Electric DD-6040 Power Button Replacement: étape 2, image 2 de 3 Mitsubishi Electric DD-6040 Power Button Replacement: étape 2, image 3 de 3
    • Once the screws are removed, slide back and remove the cover.
  3. Mitsubishi Electric DD-6040 Power Button Replacement: étape 3, image 1 de 3 Mitsubishi Electric DD-6040 Power Button Replacement: étape 3, image 2 de 3 Mitsubishi Electric DD-6040 Power Button Replacement: étape 3, image 3 de 3
    • Gently pull out the green circuit board.
    • Be very careful, as circuit boards can be quite fragile.
  4. Mitsubishi Electric DD-6040 Power Button Replacement: étape 4, image 1 de 2 Mitsubishi Electric DD-6040 Power Button Replacement: étape 4, image 2 de 2
    • Flip the DVD player over and pull up on the clip.
  5. Mitsubishi Electric DD-6040 Power Button Replacement: étape 5, image 1 de 3 Mitsubishi Electric DD-6040 Power Button Replacement: étape 5, image 2 de 3 Mitsubishi Electric DD-6040 Power Button Replacement: étape 5, image 3 de 3
    • Once the clip is unlatched disconnect the corner tabs.
    • Reorient and unlatch the tabs inside the device.
    • Remove the faceplate.
  6. Mitsubishi Electric DD-6040 Power Button Replacement: étape 6, image 1 de 3 Mitsubishi Electric DD-6040 Power Button Replacement: étape 6, image 2 de 3 Mitsubishi Electric DD-6040 Power Button Replacement: étape 6, image 3 de 3
    • Pull on the old power button to remove it.
  7. Mitsubishi Electric DD-6040 Power Button Replacement: étape 7, image 1 de 2 Mitsubishi Electric DD-6040 Power Button Replacement: étape 7, image 2 de 2
    • Adjust and push the new button into place.
To reassemble your device, follow these steps in reverse order.
Usha Alexis
Membre depuis le 01/12/20
199 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 membres
30 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 371
