Aller au contenu principal
Modal MD-SPBT01 LED Light Wiring Replacement
Ce dont vous avez besoin
  1. Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: étape 1, image 1 de 2 Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: étape 1, image 2 de 2
    • Use your plastic opening tool to pry the metal speaker cover off.
  2. Modal MD-SPBT01 LED Light Wiring Replacement: étape 2, image 1 de 1
    • You can now use the Phillips #00 screwdriver to remove the four screws.
  3. Modal MD-SPBT01 LED Light Wiring Replacement: étape 3, image 1 de 1
    • With the screws removed, you can now remove the top piece of the speaker to gain access to the interior.
  4. Modal MD-SPBT01 LED Light Wiring Replacement: étape 4, image 1 de 1
    • Locate the LED wire connection and remove it from the mother board.
    • To make replacing the LED wiring easier, remove the speaker wire to fully disconnect the speaker from the mother board.
  5. Modal MD-SPBT01 LED Light Wiring Replacement: étape 5, image 1 de 1
    • Now you can remove the wiring from the speaker side of the device.
    • It might take a bit of work to remove the wires because they are glued down on this side.
  6. Modal MD-SPBT01 LED Light Wiring Replacement: étape 6, image 1 de 1
    • Now with the LED wiring removed, a new wire can be installed.
Nathan Hall
Membre depuis le 10/13/15
258 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 2-4, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 2-4, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 641
