Introduction
The following steps in this guide explains how to replace the LED lights in the MODAL WORCSS6 wine opener. The LED lights are important to be able to see where the corkscrew is when approaching the wine bottle. The LEDs also create a nice visual display for guest or the user. This guide will require soldering, so check out this soldering guide if you are unfamiliar with the process.
Ce dont vous avez besoin
Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
Using the jimmy tool, carefully pry off the black plastic ring.
Remove the spring assembly from inside the transparent plastic tube.
Slide the circuit board out of its slot.
Remove the LEDs by clipping off their connections with a pair of tweezers.
Attach the new LEDs by soldering the ends of the LEDS to their corresponding connections on the circuit board.
